PostGre ST_RASTER Error getValue
425
08-24-2017 10:22 AM
FabianHeredia
Hi
when i execute
SELECT getValue(raster,1,0,se_coord(-75,4)) r,
FROM [Scheme].[RasterDataSet] WHERE raster_id(raster) = 1;
the GDB say:
NOTICE: ESRI: ST_Coord start
NOTICE: ESRI: ST_Coord end
NOTICE: ESRI: ST_Raster_getValue start
NOTICE: ESRI: prepare SELECT count(*) FROM INFORMATION_SCHEMA.tables WHERE lower(TABLE_CATALOG) = current_database() AND lower(TABLE_SCHEMA) = current_schema() AND lower(TABLE_NAME) = lower($1)
NOTICE: ESRI: prepare returned success
NOTICE: ESRI: prepare select srid from sde.sde_raster_columns where rastercolumn_id = $1
NOTICE: ESRI: prepare select row_nbr, col_nbr, block_data from sde_blk_22 where rasterband_id = $1 and rrd_factor = $2 and row_nbr >= $3 and row_nbr <= $4 and col_nbr >= $5 and col_nbr <= $6
the last select dont have [Scheme] and does not run well
the correct sentence id select row_nbr, col_nbr, block_data from [Scheme].sde_blk_22
but the sentence is controlled by ST_Raster Lib
