Recreate All Spatial Indexes at once?
1094
07-20-2018 11:22 AM
MattStull
New Contributor III
I just upgraded by Enterprise Geodatabases from SQL Server 2005 to SQL Server 2014 and now I am getting the "Failed to compress the database.  Underlying DBMS error [dbo.DEFAULT]" error message.  From looking at other people's questions, it looks like I need to recreate the spatial indexes on all my feature classes.  My question is:
Is there a tool or script that will recreate all of the feature classes in my geodatabase at once?  So I don't have to do it one at a time?
JoeBorgione
Conceptually you can use the RebuildIndexes_management() in a loop.  Something like this: (untested!)
import arcpy
arcpy.env.workspace = r'X:\use\path\of\connection\file
fcList = arcpy.ListFeatureClasses()
for fc in fcList:
    arcpy.RebuildIndexes_management(fc)
That should just about do it....
Asrujit_SenGupta
MVP Regular Contributor
Rebuild Indexes—Help | ArcGIS Desktop
The tool can be used directly. Just select the SDE Connection file..
MattStull
New Contributor III
Thank you for the help Asrujit!
Matt
