Schema XML editor
3503
08-18-2016 10:52 PM
Siva_Sankara_ReddyKallam
Dear all,
can anyone suggest schema editor for the XML exported from GDB and after edits to import it back
DanPatterson_Retired
are you looking for the structure ? Geodatabase XML—Help | ArcGIS for Desktop
How to import it? Importing a geodatabase schema from an XML workspace document—ArcGIS Help | ArcGIS for Desktop
How to export it? Exporting a geodatabase schema to an XML workspace document—ArcGIS Help | ArcGIS for Desktop
the whitepaper? XML Schema of the Geodatabase
or this link ?? Documenting your geodatabase design—ArcGIS Help | ArcGIS for Desktop with its downloads and links
or a free external editor? (see options for editors on the web if current tools aren't sufficient
Yes, we are looking a tool lke arcgis diagrammer or a tool that can help us edit the schema experted as xml and to help us define all changes
then we can use import xml tools in arcgis
I updated the link with this Documenting your geodatabase design—ArcGIS Help | ArcGIS for Desktop there are links in there, but I haven't tried the options.
George_Thompson
Esri Frequent Contributor
To add to what Dan has documented: A note about the use of UML for geodatabase design—ArcGIS Help | ArcGIS for Desktop  there is a 3rd party tool called Sparx Enterprise Architect: ArcGIS Geodatabase Design | UML | Enterprise Architect
--- George T.
