Spatial Indexing Issue
3353
12
08-09-2020 12:52 AM
AdnanYounas2
Whenever I create a new feature class with ST_Geometry column, It's created without any issue but I cannot insert data into it until unless I remove the spatial index from it.
I have tried the following things:
1- Also when I delete the Spatial Index I can enter the data and all works fine but
2- Later if I want to create a spatial Index on the same layer, it doesn't work. I can click on the "create" button but no spatial index name appears or
3- If I do it through the tool it says "Succeeded" about the spatial index creation but cannot see the index.
4- Rebuild Index button is disabled.
Any suggestion, why is this behavior and how to fix it?
ArcGIS Desktop 10.6.1, ArcSDE 10.6, Oracle 19c.
Younus
Asrujit_SenGupta
MVP Regular Contributor
I am assuming that your geodatabase is upgraded to 10.6.1.
AdnanYounas2
Thanks for your response.
The Client and Server both are on 10.6.1.
We are facing the ST_Geometry related issue on this Database with almost all the schemas I have checked so far.
We have another environment but different version and working fine with same data.
Any clue?
A
DavidPike
MVP Frequent Contributor
is it registered with the gdb?
AdnanYounas2
Yes, I verified it and it is registered in all the SDE referenced tables.
George_Thompson
Esri Frequent Contributor
Here is the other thread with the same question: Spatial Indexing Issue
Adnan Younas‌ - in the other thread you mentioned running the Create Spatial Type (Data Management)—ArcMap | Documentation tool.
Is this the only tool that you ran on the Oracle DB?
If so, this does not create an Enterprise Geodatabase and may be part of the behavior.
--- George T.
AdnanYounas2
No, what I was trying to suggest what if I re-ran this tool  Create Spatial Type (Data Management)—ArcMap | Documentatiagain to fix any anomalies left behind?
As I have checked almost everything I could think of and database got all the references of spatial index but with the spatial index we cannot insert data and if I remove it all works except I cannot recreate spatial index using ArcCatalog etc.
George_Thompson
Ok, did you run the Create or Enable Enterprise Geodatabase tool also?
If so, before or after you ran the Create Spatial Type GP tool?
If you ran both, I am wondering if there is an issue behind the scenes.
--- George T.
AdnanYounas2
It was upgraded from 10.2.2 to 10.6.1.
I am not sure about when it was ran but I guess we didnt run after the upgrade.
Also an interesting fact with more experiments on the schema:
User --> Schema owner: I inserted data into the table with spatial index enabled --> worked fine without an issue and row inserted.
Application User: Same Insert statement ran with spatial index and got the following error with the spatial index but data was inserted when I removed the spatial index. Checked the permissions though and looks fine.
ERROR at line 1:
ORA-29875: failed in the execution of the ODCIINDEXINSERT routine
ORA-00942: table or view does not exist
ORA-06512: at "SDE.SPX_UTIL", line 1147
ORA-06512: at "SDE.SPX_UTIL", line 1204
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 2023
After interesting the data now I cannot create the spatial index same problem I mentioned earlier.
I hope I manage to explain it well. Please suggest.
Thanks.
George_Thompson
Honestly at this point, I would work with technical support on this issue. They may be able to help narrow down the issue based on the workflow.
If you upgraded from 10.2.x --> 10.6.x, then you would NOT need to run the Create Spatial type or Enterprise GDB tools after the upgrade.
--- George T.
