Unable to create new database connection file.
4891
5
05-11-2018 12:19 AM
AjitkumarBabar
Occasional Contributor II
"Unable to create new database connection file, permission is denied" error is coming while trying to add database connection in ArcCatalog.
sql 2014 & pg 9.5
Asrujit_SenGupta
MVP Regular Contributor
It sounds like somehow, you don't have write permissions to the directory where the connection files are created.
Try these:
Asrujit_SenGupta
You need to provide more details, such as..
  • What is the version of ArcGIS Desktop being used?
  • Database version (example: SQL Server 2014 SP2 or PostgreSQL 9.5.x ?)
  • Issues happening on one machine only?
  • Issues happening while connecting with particular login or any login?
  • Error screenshot
  • Have you successfully created database connections on this machine before?
AjitkumarBabar
  • What is the version of ArcGIS Desktop being used? - 10.6
  • Database version (example: SQL Server 2014 SP2 or PostgreSQL 9.5.x ?) - SQL Server 2014 - SP1 & postgresql-9.5.10-2
  • Issues happening on one machine only? - Yes
  • Issues happening while connecting with particular login or any login? - With all the logins
  • Error screenshot - Attached
  • Have you successfully created database connections on this machine before? - This is the first time
Asrujit_SenGupta
Try these:
AjitkumarBabar
Running ArcCatalog as an Administrator didn't help but Create Database connection partially resolved the issue.
Thanks for the help.
YungKaiChin
One workaround is to create a database connection file (*.sde) on a different computer and transfer the connection file.
In my case, ...
  • The user can create the database connection file and connect to the database on a different computer.
  • The user can create the database connection file and connect to a different database on the same SQL Server.
  • The user has rebooted the computer without resolving the issue.
