When executing sdetable command from command prompt I am getting an Underlying DBMS error(-51).
I have Oracle 11g database with ArcSDE 10.1 installed.
Following is the sdetable command,
sdetable -o describe -t sites -i sde:oracle11g:mydb -s 10.169.43.22 -u sde -p sde
Following is the result:
Error: Underlying DBMS error (-51).
Error: Could not create a connection on server 10.169.43.22, for user sde
Extended DBMS error code: -1
Unknown error
No extended error.
Following is the log in sdedc_Oracle.txt:
DB_open_instance()::db_connect (OCI8) error: -1
CAN'T OPEN INSTANCE: sde:oracle11g.
Spatial Engine Connection Failed (-51).
Cannot Get Access to Instance sde:oracle11g
Any insight on these type of errors and the probable reasons that could have led this error is appreciated.
