Update enterprise geodatabase using Import XML Workspace document
313
12-03-2019 05:15 AM
Cristian_Galindo
There are two geodatabases DEV and PROD, DEV has schema changes (new fields, new tables), those changes should be replicated on PROD.
An XML schema was generated from DEV, and using the Import XML Workspace tool is intended to update PROD, but the result is that the new tables modified in DEV now appear in PROD with _1 sufix:
DEV                         PROD
MyTable                     MyTable_1
    NewField                    NewField
    OldField                MyTable
                                OldField
How could achieve this update?
