A column was specified that does not exist.
171
4 weeks ago
GeoIKGS
I'm running a Python script for ArcPro 3.2 where I am using the Select Layer by Attribute tool to select "FEAT_CODE LIKE 'WARV50' OR FEAT_CODE LIKE 'WALK%'" and it returns the error in the title. I've gone into Pro and double checked the attribute table to confirm these features are there and the field is there, all correctly named, yet still with the error. I've run the same tool on three other layers without issue. Any help would be appreciated, thanks.
Marco_AlejandroBonilla
The code seems OK, can you share the "Design" -> "Fields" table from ArcGIS Pro pointing to the Data Source view?
