Using ArcGIS 9.3.1, I successfully executed an Intersect between two polygon shape files (I tried intersecting 3 shape files first but the license won't allow that apparently. So, I then tried to intersect the successful intersection with the third file, using a second Intersect. This repeatedly fails. I tried the same Intersect at another institution using Arc10.0 but got the same failure. Is Arc detecting that one of the files is already the product of an intersect and therefore denying me the chance to intersect a third file? The error message I get is:
Executing: Intersect "'Intersection_diek buffer_F2 buffer' #;'br200k_lithological_unit_prospective units' #" "L:\Nero_Alternate\Kuusamo_GIS\Finnish GTK stuff\FS_Geology\200k_Finland_tm35Fin\Arc translations\Intersection_dike_F2_prospunits.shp" ALL # INPUT
Start Time: Thu Jul 27 09:36:41 2017
Reading Features...
Cracking Features...
ERROR 999999: Error executing function.
Invalid Topology [M coord limit exceeded.]
Failed to execute (Intersect).
End Time: Thu Jul 27 09:36:43 2017 (Elapsed Time: 2.00 seconds)
ALso if you are able to share the shapefiles we could determine if it is a differnece of versions.
How does one attach a shape file John?
Zip up the shapefiles - you can upload them to a google drive or equivalent and share the link that way
John
I’ve uploaded the files to Dropbox (KSfiles.zip). It is shared with geonet@esri.com
Cheers
Walter
When I have had erase or intersect tools fail with ArcMap, I usually try:
But I also noticed your error message referred to "Invalid Topology [M coord limit exceeded.]" You can try converting your shapefile to a new one with M Values set to Disabled under the Environment settings.
It has been many years since I opened ArcMap 9.3 so what I have written above applies to ArMap 10.x but I am hoping this functionality was available In 9.3
Nice ideas Mervyn but no success, I'm afraid.
Try to export them to new shape files and retry.
The files are now uploaded to Dropbox and shared with geonet@esri.com. The folder is called KSfiles.zip
