arcpy.Clip_analysis produces feature output without spatial reference
721
08-21-2020 01:02 PM
MichaelJust
When I use `arcpy.Clip_analysis()` in a stand-along Python 3.6 script, the output is missing a spatial reference. When I complete the task within ArcGIS Pro using the GUI, the feature output maintains the spatial reference.
The input feature, the clipping feature, and the output feature are each in a different file geodatabase. The clipping feature is a polygon and the clipping feature can be point, line, or polygon; I am experiencing the same issue with each feature type. The input feature and the clipping feature are both projected with "USA Contiguous Albers Equal Area Conic USGS."
Is there something I can change int the environmental settings? Other suggestions?
MichaelJust
arcpy.env.outputCoordinateSystem = arcpy.SpatialReference(102039)
Seems to have solved the issue. Is this best practice when working with feature data?
DanPatterson
MVP Esteemed Contributor
Michael Just‌ I would say yes, because explicit is better than implicit, especially is you look at all the considerations involved in determining an output coordinate system
Spatial reference and geoprocessing—ArcGIS Pro | Documentation
Even though Clip supports the coordinate system environment variable, why assume
... sort of retired...
