Wes,
Thanks!
I ran the model and it failed with this error:
Assembling Features...
Succeeded at Mon Jan 25 11:06:26 2016 (Elapsed Time: 2 minutes 4 seconds)
Executing (Generate Near Table): GenerateNearTable in_memory\roadsIntersect in_memory\Roads_Intersect_Buffer_Inter in_memory\nearTable "51 Feet" NO_LOCATION ANGLE ALL 0 PLANAR
Start Time: Mon Jan 25 11:06:27 2016
Determining data processing extents...
Building a neighborhood index from the Near Features...
Generating Near Table...
Found 346 feature(s) within 51.000000
Succeeded at Mon Jan 25 11:06:27 2016 (Elapsed Time: 0.56 seconds)
Executing (findLessThanAngle): findLessThanAngle 50 5 in_memory\roadsIntersect in_memory\nearTable
Running script findLessThanAngle...
Failed script findLessThanAngle...
File "Y:\GISData\Tools\FindAngletoolbox\findAngle.tbx#findLessThanAngle.py", line 37, in <module>
NameError: name 'each' is not defined
Failed to execute (findLessThanAngle).
Failed at Mon Jan 25 11:06:28 2016 (Elapsed Time: 0.23 seconds)
I deleted the "each" out of the python code, ran it, but it only gave me 22 intersecting roadways with angles of < than 50 degrees out of 2299 total...I wasn't sure if it was my python code editing that gave me the short list.
I know very little about python. It is in my toolbox of things to do, no pun intended.
Other than that, it does look promising!
Thanks again for your help!
