Clip Function
809
05-02-2012 01:09 AM
SamGladwin
I have a dataset that I am trying to clip using both outside and inside types as shown in the attached file.  I have a polygon feature class that I am using to clip the raster with.  I don't have any trouble getting the inside clip to work, but have no idea how to achieve  the outside clip.
Can someone please help I've been trying to figure this out for a while to no avail.
Sam
DanPatterson_Retired
If you have an ArcInfo license then use Erase http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00080000000m000000
otherwise Union the two files, then manually delete the intersecting area
