I am attempting to set up a model that will clip two separate rasters to the bounds of a polygon. The polygon is in a FC that serves as an AOI. I want to clip NLCD land cover and NLCD tree canopy to this AOI. Model is set up like so...
Not running/verifying the model inside the model environment because in application it will be used as a tool - see below.
I have linked the AOI variable as both the Rectangle and the Extent parameter of both Clip Raster tools. The error I am getting is ERROR 000964: Specified extent is invalid.
When I run this outside of the model, just using the geoprocessing tool, it is successful on both rasters.
Any ideas? TIA.
