Drawing polylines with specific angles
7349
05-07-2012 06:08 AM
yaskshelat
Hi
I am a geologist, I have some drill hole data.
I would like to draw the direction of drillholes (collar) using the polylines.
Is it possible that I can draw polylines with specific angles i.e., 0 degrees (north) , 90 degrees, 75 degrees etc. This way a polyline would orient exactly the same way as the angle mentioned.
I tried to use direction/length option (this option comes when I right-click the polyline while drawing it) This option does not allow to choose the angle. I am not sure how to use this option properly. Please suggest.
Yask
DanLee
by Esri Regular Contributor
I am not sure if your polylines already exist and you just want to rotate them or you have points as starting points to draw or create the lines.
If you are asking a drawing question (using points as reference?), you may want to post this at the Cartography forum:
http://forums.arcgis.com/forums/41-Cartography
If you need to create polylines with bearings, you can try Bearing Distance To Line (new in ArcGIS 10):
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//0017000000ts000000
You need to prepare the required fields in a table as input.
yaskshelat
Thanks I think "bearing distance to line" worked for me.
I entered the UTM coordinates, length and bearing, and it worked perfect for me. Now its possible to draw the lines according to the collar (strike) of the drill hole
Yask
DanLee
You are welcome. I am glad the tool worked for you.
