In order to find a workaround I tried to use a script with multiprocessing.
Unfortunately, it has an error at the run time. Please help to make it working.
The script
#run “Manage Tile Cache” tool in parallel processing
import arcpy
import multiprocessing
import os
import glob
import sys
import traceback
from multiprocessing import Process, Queue, Pool, \
cpu_count, current_process, Manager
arcpy.env.scratchWorkspace = "in_memory"
AAA_Imagery = "D:/gisdata/imagery/public_AAA_Imagery/AAA_Imagery"
Manage_Mode = "RECREATE_ALL_TILES"
Scales__Pixel_Size___Estimated_Disk_Space_ = "564.248588"
Best_WebM = "D:/gisdata/imagery/BestMosaic_2017test.gdb/Best_WebM"
Level_20_coverage = "D:/gisdata/imagery/Levels_coverage.gdb/Level_20_coverage"
def execute_task(bundleAOI):
try:
result = arcpy.ManageTileCache_management(AAA_Imagery, Manage_Mode, "", Best_WebM, "ARCGISONLINE_SCHEME", "", Scales__Pixel_Size___Estimated_Disk_Space_, bundleAOI, "", "591657527.591555", "282.124294")
print(arcpy.GetMessages())
print "result: " + result
except Exception, e:
e.traceback = traceback.format_exc()
raise
if __name__ == '__main__':
#get individual bundles, add it to a dictonary
bundles = {}
count = 1
for bundle in arcpy.da.SearchCursor(Level_20_coverage,["*"]):
bundles[count] = bundle
count += 1
# create a process pool and pass dictonary of extent to execute task
pool = Pool(processes=cpu_count())
pool.map(execute_task, bundles.items())
pool.close()
pool.join()
The error (see the image)
