This worked! I completely ignored the select line of code and used feature class to feature class with the above suggestion for the SQL expression and got the intended result!
Below is the line of code that worked. I simply changed the variables for each item as necessary
arcpy.conversion.FeatureClassToFeatureClass(out_lyr, "", lived, "DES = 'lived'")
