In light of ArcGIS Server not recognizing the "Query Builder" wizard when using the Select By Attributes tool, I'm wondering if there is a way to manually construct the Query Builder? So for instance, (see attached picture) based on the user first selecting which feature layer they want to run query against, a second dropdown list would then show All the Attributes associated with that feature layer. A third dropdown list would then contain the values from which attribute the user chose. So for example, If I wanted to run this Query "Active" = 'N' on the Wells layer. Does anyone have any python to get me started here?
many thanks
