How to convert from E, N, Z data to TIN
2492
5
10-22-2015 01:24 PM
KONPETROV
Occasional Contributor III
Hi, i have a file in a geodatabase that in its at attribute table has the columns: OBJECTID, SHAPE, E, N, Z. I know that it should be a TIN file but i don't have it like that in my workspace, but as points. I have no idea from geodatabases, and why it is in that form there? It has been maden form LiDAR data that is for sure.
Any idea how can i convert it to TIN?
DarrenWiens2
MVP Honored Contributor
Use the Create TIN tool on those points.
If they're not points already, make them into points first, using the coordinates.
DanPatterson_Retired
looks like the table that already has coordinates, hence the Shape field.  any more info? or is that all there is, just the table
KONPETROV
only that data i wrote
DarrenWiens2
KONPETROV
I tried it and worked fine. Thank you very much . I have one more question, would it be more correct if i had tranformed them firstly in .LAS through txt2las and then from LAS to TIN?
NeilAyres
You started with a point feature. So the approach outlined by Darren is perfect.
Actual LAS files are a different thing altogether. If you have a collection of LAS files, create a lasd dataset using Catalog and go from there.
