Input vector = shapefile with many overlapping polygons
Identify feature = only one polygon
When the identify feature crosses the input feature I receive two or more readings (with the same FID) due to the fact that the identity feature many times crosses the polygons within the input feature class. See it below:
fid 1319, 885 - 1
fid 1319, 347 - 0
(1 within, 0 - outside)
Could I set up my code in a way (or use other function), that the input polygon is either and only in or out of the identify feature but not in both, even though the identity feature crossed it?
arcpy.analysis.Identity(fc, idFeat, output, "ALL", relationship="NO_RELATIONSHIPS")
