In order to find out the population of the buffer zone in Arcgis
1133
6
02-24-2022 01:41 AM
AjitYadav
Hello, Esri community I need how to find the population in the buffer zone.
Kindly provide me with the process.
shan_sarkar
Hi @AjitYadav
Could you give more information on what other operational layers you have in the map for this analysis?
~Shan
AjitYadav
I Have projected population data sedac (Projected population density of India, 2020) data in tiff formate and I have created a 10 km buffer map Now I would like to calculate the population in the buffer zone.
JayantaPoddar
What inputs do you have (from which population data would be extracted)? Screenshots would help.
Think Location
AjitYadav
I am Using Sedac projected population density of India 2020.
sedac.ciesin.columbia.
DanPatterson
unless the population is uniformly spread out across the landscape, making the assumption that you can translate "population density" to "population" within the buffer is a conceptual stretch,  You also have floating point values for density which rules out "Tabulate Area" and "Zonal Statistics" or "Zonal Statistics as Table" would necessitate taking the average density, which might be ok if the buffer is relatively uniform.  Use density values with caution.  It would be better to acquire actual populations data on a polygon basis if it is at all possible.
... sort of retired...
AjitYadav
Hi
I have done.
Thank you
