Is it possible to extract more than one attribute using Extract Multi Values to Points?
2539
01-05-2016 10:02 AM
TimothySandstrom
New Contributor III
I noticed the Extract Values to Points allows the user to extract all attributes within a raster dataset.  However, I do not see that capability within Extract Multi Values to Points.  Am I missing something?
DanPatterson_Retired
Extract Multi Values to Points—Help | ArcGIS for Desktop
You can extract band information if it is an image
You can extract information from multiple rasters
But... any tabular information...which I presume you have joined, will not be extracted.
You might be able to join the extra tabular information that you need, since the tool, by design, extracts the cell value from the raster and a cell can only have one 'value'
SteveLynch
Integer rasters can have additional attributes and as Dan suggests you can join these raster tables to the output point feature class then use CopyFeatures to persist the join.
-Steve
