Join field to a polygon shapefile from another overlapping polygon in ArcGIS 10.1
1390
03-20-2017 04:10 AM
SlobodanKomatina1
I have two polygon shapefiles (parcel and zoning). Parcel shapefile is overlapped by zoning shapefile. Parcel layer does not contain information about zone and I want to add that information to each parcel from zoning shapefile.
My idea is to create centroids from parcel shapefiles and after that to join zoning shapefile by location. On that way, I will add zoning attributes in my centroid point file. When I finish that I will join by location that point file and my parcel file. Unnecessary fields could be deleted after that.
I need to know is there any faster way to finish this job in ArcGIS 10.1?
This is a screenshot of a part of my parcel shapefile: enter image description here
This is a screenshot of a part of my zoning shapefile: enter image description here
Just to note that this is a very large data, about 800000 parcels.
JayantaPoddar
MVP Esteemed Contributor
Your methodology sounds good.
Are there parcel boundaries which overlap with two or more zoning boundaries? If yes, what you want to do with those parcels?
If you want one parcel should contain information of one zoning boundary, your method is better than Polygon-to-polygon spatial Join.
NOTE: One advice would be to work with File Geodatabase, if there is a chance of the shapefile size to exceed 2 GB size limit.
Think Location
EdwinRoa
Hi
try to use a SpatialJoin
SpatialJoin_analysis (target_features, join_features, out_feature_class, {join_operation}, {join_type}, {field_mapping}, {match_option}, {search_radius}, {distance_field_name})
This tool is available in ToolBox.
Edwin
JayantaPoddar
Think Location
SlobodanKomatina1
It is looks like a one parcel have just one zoning overlay.
SlobodanKomatina1
The method with centroids is not good for a streets, because the centroids of street polygons are out of street boundary and after that could be joined to wrong zone. Otherwise, when I use polygon to polygon my streets have a zone information from nearby zone overly and I am not sure why.
