joining polylines
821
13
03-31-2013 12:26 PM
MalgorzataMendela
New Contributor III
could you please help me to join two features (geometry type: polyline), knowing that these datasets do no have common parts (they are disjoint)? Which ArcGIS tool would be appropriate to solve this problem?
Thank you for your advice.
Best wishes,
Malgosia
JakeSkinner
Esri Esteemed Contributor
Hi Malgosia,
You could perform a spatial join.  This tool will allow you to specify a search radius and the attributes from the one polyline shapefile will be joined to the other.
MalgorzataMendela
New Contributor III
thank your for your advice.
I have performed a spatial join, but unfortunately I have not received desireable results. The output feature class is the same as one of the input feature classes (thin_shp_Ob17.shp), defined as input data in the 'target features' field of the spatial join tool.
Could you please let me know what I should do to join these polylines properly?
I would be grateful for your help.
Best wishes,
Malgosia
JakeSkinner
Are you looking to merge these two shapefiles together?  You can do this using the Merge tool.
MalgorzataMendela
New Contributor III
I am looking to join them, but in such a way, that the the thin_shp_ob17.shp would contain the Line_from_Point feature class.
Merge is not a good tool , because it gives one feature class consisting of both input datasets (thin_shp_ob17.shp and Line_from_Point.shp) with no change of geometry of the thin_shp_ob17 feature class).
TarunJaiswal
Greetings Malgosia!
Check out the Snap tool.
You will at least need ArcGIS for Desktop Standard License Level to run this tool.
Hope this helps.
Thanks!
MarkBoucher
Occasional Contributor III
How about single-part to multi-part?
MalgorzataMendela
New Contributor III
concerning snap tool, it is not good solution as it allows only for manual movement of points or vertives- I need a tool which could process data automatically.
Best wishes,
Malgosia
MalgorzataMendela
New Contributor III
Do you mean multipart to singlepart?
It is also not good, because I need exactly an opposite result to the given by this tool.
Does ArcGIS have the singlepart to multipart tool?
MarkBoucher
I meant single-part to multi-part. See this link. It might help. I don't have time to test this.
http://forums.arcgis.com/threads/8942-singlepart-to-multipart
