Loop through rasters and extract by masks of polygon fcs with same names
2146
12
01-26-2021 01:12 PM
KathleenHoenke
I have a gdb of 50 polygon fcs named based on HUC # abbreviation - ie: HUC_002, HUC_003, etc.
I have another gdb of rasters also based on the same state abbreviation - ie:  Pluvial_002, Pluvial_003.
I want to create a short scripts that loops through the second gdb and extracts each of the rasters by the features as masks  and output to a new gdb. For example, I want to take the raster named pluvial_002 and grab the fc named HUC_002 and use it to extract the raster by mask and output it to floodplain.gdb. Attached is my script - it runs for 2 seconds and says it's complete, but outputs nothing.
TIA!
#fgdb of rasters being clipped
source_fgdb = arcpy.GetParameterAsText(0)
#fgdb of features doing the clipping
clipping_fgdb = arcpy.GetParameterAsText(1)
#preferably empy fgdb to put outputs
output_fgdb = arcpy.GetParameterAsText(2)
#list all the rasters
arcpy.env.workspace = source_fgdb
source_rasts = arcpy.ListRasters()
arcpy.env.workspace = clipping_fgdb
clipping_fcs = arcpy.ListFeatureClasses()
#make a dictionary of source fc path
#to clipping fc and source name
#NB relies on names before the '_' being equal
source_clip_fc_dict = {}
for source_rast in source_rasts:
    for clipping_fc in clipping_fcs:
        if source_rast.split("_")[0] == clipping_fc.split("_")[0]:
            source_rast_path = os.path.join(source_fgdb, source_rast)
            clipping_fc_path = os.path.join(clipping_fgdb, clipping_fc)
            source_clip_fc_dict[source_rast_path] = [clipping_fc_path, source_rast]
#clip each source feature and output to output_fgdb
for source_rast_path in source_clip_fc_dict:
    clipping_fc_path = source_clip_fc_dict[source_rast_path][0]
    source_rast_name = source_clip_fc_dict[source_rast_path][1]
    out_rast_name = source_rast_name + "_Mask"
    out_rast_path = os.path.join(output_fgdb, out_rast_name)
    OutExtractbyMask = ExtractByMask(source_rast_path, clipping_fc_path)
    OutExtractByMask.save(out_rast_path)
2 Solutions
DanPatterson
MVP Esteemed Contributor
I don't have anything to test on, so I would suggest a well speckled interjection of print statements before and within your for and if statements to see what is going on
... sort of retired...
DavidPike
MVP Frequent Contributor
You need to define the out raster path within the loop (just below clipping_fc_path)
out_raster_name = source_rast_name + "_Mask"
out_raster_path = os.path.join(output_fgdb, out_raster_name).
DavidPike
It looks ok, but this time the logic for comparison has changed from being what was before the '_' to what's after it, right?  That's probably meaning nothing is in the dictionary.
try changing the 3rd line as indicated below.:
        if source_rast.split("_")[1] == clipping_fc.split("_")[1]:
 also for your
ExtractByMask()
I'm unsure how you've done your imports, so maybe
arcpy.ExtractByMask()
Also print statements are invaluable for troubleshooting to see what's happening along the script, and where things stop/or you can see a list isn't being populated etc.
Print out all the list and dictionary being created and you'll have a much better idea of what's going on.
DanPatterson
from arcpy.sa import *
# ==== or
from arcpy.sa import import ExtractByMask
Are your imports missing?
KathleenHoenke
I think my issue is that my dictionaries don't have anything in them.... the lists of fcs and rasters print fine...
source_fgdb = r'E:\FATHOM\2020FATHOM\Analysis\Pluvial_1in100\Pluvial_1in100_Processed.gdb'
clipping_fgdb = r'E:\Boundaries\WBDHU2_Mar2014.gdb'
output_fgdb = r'E:\FATHOM\2020FATHOM\Analysis\Final_Floodplain_Bounds_No_NHD.gdb'
rasters = arcpy.ListRasters("*", "GRID")
print (rasters)
['FATHOM_pluv_con_002', 'FATHOM_pluv_con_005', 'FATHOM_pluv_con_006', 'FATHOM_pluv_con_012', 'FATHOM_pluv_con_007', 'FATHOM_pluv_con_010', 'FATHOM_pluv_con_011', 'FATHOM_pluv_con_013', 'FATHOM_pluv_con_014', 'FATHOM_pluv_con_015', 'FATHOM_pluv_con_016', 'FATHOM_pluv_con_017', 'FATHOM_pluv_con_008', 'FATHOM_pluv_con_009', 'FATHOM_pluv_con_003']
print (clipping_fcs)
['HUC2_002', 'HUC2_003', 'HUC2_004', 'HUC2_005', 'HUC2_006', 'HUC2_007', 'HUC2_008', 'HUC2_009', 'HUC2_010', 'HUC2_011', 'HUC2_012', 'HUC2_013', 'HUC2_014', 'HUC2_015', 'HUC2_016', 'HUC2_017', 'HUC2_018', 'HUC2_019', 'HUC2_020', 'HUC2_021', 'HUC2_022']
for raster in rasters:
        if raster.split("_")[0] == clipping_fc.split("_")[0]:
            raster_path = os.path.join(source_fgdb, raster)
            source_clip_fc_dict[raster_path] = [clipping_fc_path, raster]
    print(source_clip_fc_dict)
DanPatterson
are you trying to match the numbers here eg... 002 to 002?
if so, you should replace 0 with -1 to get the last of the split
if raster.split("_")[-1] == clipping_fc.split("_")[-1]:
dct = {}
for f in fcs:
    for ra in r:
        if ra.split("_")[-1] == f.split("_")[-1]:
            dct[f] = ra
dct
{'HUC2_002': 'FATHOM_pluv_con_002',
 'HUC2_003': 'FATHOM_pluv_con_003',
 'HUC2_005': 'FATHOM_pluv_con_005',
 'HUC2_006': 'FATHOM_pluv_con_006',
 'HUC2_007': 'FATHOM_pluv_con_007',
 'HUC2_008': 'FATHOM_pluv_con_008',
 'HUC2_009': 'FATHOM_pluv_con_009',
 'HUC2_010': 'FATHOM_pluv_con_010',
 'HUC2_011': 'FATHOM_pluv_con_011',
 'HUC2_012': 'FATHOM_pluv_con_012',
 'HUC2_013': 'FATHOM_pluv_con_013',
 'HUC2_014': 'FATHOM_pluv_con_014',
 'HUC2_015': 'FATHOM_pluv_con_015',
 'HUC2_016': 'FATHOM_pluv_con_016',
 'HUC2_017': 'FATHOM_pluv_con_017'}
KathleenHoenke
Thank you! That worked! Now, the script works but only for one of the items in the dictionary (HUC2_003 and FATHOM_pluv_con_003).  It outputs that faster clipped perfectly, but then stops....
for source_raster in source_rasters:
        if source_raster.split("_")[-1] == clipping_fc.split("_")[-1]:
            source_raster_path = os.path.join(source_fgdb, source_raster)
            source_clip_fc_dict[source_raster_path] = [clipping_fc_path, source_raster]
for source_raster_path in source_clip_fc_dict:
    clipping_fc_path = source_clip_fc_dict[raster_path][0]
    source_raster_name = source_clip_fc_dict[source_raster_path][1]
    out_raster_name = source_raster_name + "_Mask"
    ExtractByMask(source_raster_path, clipping_fc_path)
    OutExtractByMask.save(out_raster_path)
DanPatterson
where is raster_path defined?  do you source_raster_path???
KathleenHoenke
I think I did in line 37 where it says source_raster_path = os.path.join(source_fgdb, source_raster) below
import arcpy
import os
from arcpy.sa import ExtractByMask
#not a fan of stating the obvious, but change the paths below to your fgdbs
#also keep the r then surround the path in quotes
source_rasters = arcpy.ListRasters("*", "GRID")
print (source_rasters)
#make a dictionary of source raster path
#NB relies on names after the '_' being equal
DanPatterson
getting confused as to why you need to do the dictionary thing, why not do the extractbymask if a match is found, basically following this idea
The dictionary is only useful if you plan to reuse it later.  You can keep the dictionary but do the extraction while you are there so you don't have to go  back and do the match thing.  (ps... I didn't pay much attention to the name matching so check!)
KathleenHoenke
Thank you! It got mad because I didn't define OutExtractByMask, so I did it below, and it then output the first pair to my default gdb with that name, and stopped. I feel like I'm so close.... something to do with how I'm doing the extraction to make sure it repeats itself.....
            OutExtractByMask = ExtractByMask(source_raster_path, clipping_fc_path)
