You may increase the parallel processing factor.
Take a smaller sample of Rasters (say 100). Test with parallel processing factor of 150% or 200%, and check how it compares to 100% (Time taken and impact on System performance).
Parallel Processing Factor
Specifying more processes than your machine has cores may incur a performance penalty. This is because multiple processes will compete for resources on one core. To specify the environment in a way that avoids this competition, you can use either a percent value less than 100% or a number of processes less than the number of cores on your machine.
However, for cases in which all your processes are I/O bound to a disk or to an enterprise database connection, you may get better performance by specifying more processes than you have cores. For example, the Add Rasters to Mosaic Dataset tool is I/O bound when the mosaic dataset is stored in an enterprise database. Also, the Build Overviews tool is primarily I/O bound to the disk. You can use more processes than your machine has cores by specifying either a percent value greater than 100% or a number of processes greater than the number of cores on your machine. For example, if you have a 4-core machine, specifying 8 or 200% will spread operations over 8 processes.
Think Location
