Oriented buffers
8087
28
02-07-2015 07:58 PM
davesacco
New Contributor II
Hi there,
I am using arcview 9.3.1 and I need to create oriented buffers from points in a shapefile. The euclidean direction method almost works, but because it calculates to the nearest point, buffers associated with points within the maximum will be truncated. I need each point to have a complete buffer in a specific direction, regardless of overlap with other points.
Any ideas would be greatly appreciated.
Dave
DanPatterson_Retired
flds = ("SHAPE@", fld_start, fld_end, fld_dist)
for the last 3, you provided numbers rather than the field names that contained the values
Hayley_DelMaynard
New Contributor II
Thanks Dan.  I really appreciate the quick response.  I changed the lines to include the field names, but I still receive the below error message:
Runtime error
File "<string>", line 40, in <module>
File "<string>", line 11, in main
AttributeError: DescribeData: Method spatialReference does not exist
>>> import arcpy
... def main():
... fc_in = "C:\Users\ihwm\Documents\ArcGIS\Flood_NT_WA.gdb\points"
... fc_out = "C:\Users\ihwm\Documents\ArcGIS\Flood_NT_WA.gdb\points2"
... fld_start = "fld_start"
... fld_end = "fld_end"
... fld_dist = "fld_dist"
... sr = arcpy.Describe(fc_in).spatialReference
... arcpy.env.overwriteOutput = True
... flds = ("SHAPE@", fld_start, fld_end, fld_dist)
... lst_polygons = [1]
... with arcpy.da.SearchCursor(fc_in, flds) as curs:
... for row in curs:
... pnt_g = row[0]
... start = row[1]
... end = row[2]
... length = row[3]
... circle = pnt_g.buffer(length)
... pnt = pnt_g.firstPoint
... arrPnts = arcpy.Array()
... arrPnts.add(pnt)
... for bearing in range(int(start), int(end) + 1):
... arrPnts.add(createPointAtAngleWithBearing(pnt, bearing, length))
... polygon = arcpy.Polygon(arrPnts, sr)
... lst_polygons.append(polygon)
... arcpy.CopyFeatures_management(lst_polygons, fc_out)
... def createPointAtAngleWithBearing(pnt, angle, distance):
... import math
... angle = math.radians(angle)
... dist_x, dist_y = (distance * math.cos(angle), distance * math.sin(angle))
... return arcpy.Point(pnt.X + dist_x, pnt.Y + dist_y)
... if __name__ == '__main__':
... main()
Runtime error
DarrenWiens2
MVP Honored Contributor
It may be having issues with escape characters in the lines where you specify the paths. Try adding an 'r' to denote raw string notation:
e.g.
fc_in = r"C:\Users\ihwm\Documents\ArcGIS\Flood_NT_WA.gdb\points"
Hayley_DelMaynard
New Contributor II
Thanks, Darren!  I'm still getting the same message.  Could it be because I'm using Arcgis 10.4.1 and that code was written for an earlier version?
>>> import arcpy
... def main():
... fc_in = r"C:\Users\ihwm\Documents\ArcGIS\Flood_NT_WA.gdb\points"
... fc_out = r"C:\Users\ihwm\Documents\ArcGIS\Flood_NT_WA.gdb\points2"
... pnt_g = row[0]
... start = row[1]
... end = row[2]
... length = row[3]
... import math
... main()
Runtime error
I just tried your code reference to the spatial reference object and it worked... you have a file issue or a disconnect to arcpy for some reason.
inFC
'C:\\Data\\points\\fishnet_label.shp'
sr = arcpy.Describe(inFC).spatialReference
sr.name
'NAD_1983_CSRS_MTM_9'
DarrenWiens2
Are you sure 'points' is a feature class and not a nonspatial table, that wouldn't have a spatial reference?
Hayley_DelMaynard
New Contributor II
Hi Darren,
Thanks again for all your help.  I started over, taking a subset of my data and creating a feature class layer of 500 points saved in the Default gdb (FloodTestFC).
This is the code I use:
import arcpy
... def main():
... fc_in = r"C:\Users\ihwm\Documents\ArcGIS\Default.gdb\FloodTestFC"
... fc_out = r"C:\Users\ihwm\Documents\ArcGIS\Default.gdb\FloodTestFC2"
... pnt_g = row[0]
... start = row[1]
... end = row[2]
... length = row[3]
... import math
... main()
And this is the error message:
Runtime error
File "<string>", line 31, in main
File "c:\program files (x86)\arcgis\desktop10.4\arcpy\arcpy\management.py", line 2335, in CopyFeatures
raise e
RuntimeError: Object: Error in executing tool
DarrenWiens2
Shouldn't it be 'lst_polygons = []'? The way it is now, I think it's getting hung up trying to make a polygon out of the number 1.
Hayley_DelMaynard
New Contributor II
IT WORKED!!!!  Thank you SOOOO much!!  I can't believe how quickly you responded and how helpful your advice was.  Honestly, thanks again so much!
