Python script/expression for field calculator for converting bearings to directions?
7335
28
09-22-2016 10:03 AM
bobcostanza
New Contributor II
I have a double field with bearings/azimuths (numbers) and I need them in letter directions: N, NE, NW,etc. I would like to calculate them in  a new field.  I have searched high and low for the code to use in the field calculator but I have failed to figure it out.
Bob
DanPatterson_Retired
FYI  I haven't accounted for changes in the polar axis since this thread was begun
bobcostanza
New Contributor II
Better get on it
Sent from my iPhone
bobcostanza
New Contributor II
Dan,
the field I was using your script in was a text field but it still failed to execute.  One of the error messages in the Geoprocessing results is "The field is not nullable. [dir] ".  Is that the problem?
dir is the field I was working on, Bearing is the field with the angles
Thanks a million,
Bob
you didn't switch to the python parser did you
bobcostanza
New Contributor II
Dan,
The field is text, the parser is python. Attached is a screenshot of what
it looks like. I am using the script from Sep 23, 2016 10:38 AM
I am just copying and pasting the script, other then specifying the
bearing field do I need to do anything else?
Thanks again,
Bob
number is selected as the field type instead of
A small but important fact... your 'bearings' appear to go from -180 to 180 instead of 0-360 as expected by the code.  I think the angles are relative to the X axis and not compass bearings.  This will have to be fixed on your end.
I could fix the code to do this but it would go from a simple expression expecting a specific input to one that accommodates all possible variants of angle types.
bobcostanza
New Contributor II
Dan,
The script on *https://community.esri.com/blogs/dan_patterson/2016/09/01/distance-calculations-using-the-field-calculator
<https://community.esri.com/blogs/dan_patterson/2016/09/01/distance-calculations-using-the-field-calculator>*
returns angles between successive points, is there a script anywhere that
returns bearings or azimuths? Do any of the other suggested scripts I
received a couple weeks ago return azimuths or bearings between successive
points? Once I have bearings I can then use the *Convert Azimuth to
Compass Bearing *script.
Bob
the first link contains the angle code for successive points and ... a variant of the code that I have posted in several incarnations in this thread... I just wanted to consolidate the field calculator geometry 'stuff' in one place as I think of it.
jarbaslima55dias
I am using the following script in ArcGIS 10.3 to calculate Quadrant (in the format angle/NE/SE/SW/NW) from azimuth. See example in:
: https://support.esri.com/pt-br/knowledge-base/instruo-calcular-a-direo-da-linha-em-lote-usando-a-cal...
def quadrant(NorthAzimuth):
 if ((NorthAzimuth>=0) & (NorthAzimuth<90)):
quad = 'N '+str(NorthAzimuth)+' E'
elif ((NorthAzimuth>=90) & (NorthAzimuth<180)):
quad = 'S '+str(180-NorthAzimuth)+' E'
elif ((NorthAzimuth>=180) & (NorthAzimuth<270)):
quad = 'S '+str(NorthAzimuth-180)+' W'
else:
quad = 'N '+str(360-NorthAzimuth)+' W'
return quad
The box Show Codeblock is cheked. This script is copied in the box Pre-logic Script Code.  In the box below - "Quadrant = " is typed quadrant (!NorthAzimuth!).
My polyline shape file contains the followings fields: Start_X (double), Start_Y (double), End_X (double), End_Y (Double), Compriment (double) - polyline lenght, and NorthAzimu (double) - azimuth in degrees.
I already replace the term NorthAzimuth of script with NorthAzimu, but without sucess.
The script always returns an error message.
Please, where is the error?
