Hi all, I have built a model in ArcGIS pro. the tools are buffer then select by location then make a feature layer. I am a little confused on how to control the symbology output for the buffer colors and transperancy once you run the model. The original layers are points, when I run the model the buffers and dissolve are bright pastel colors how do I control the symbology output with apply symbology layer?
