Raster projection defined, but unknown geographic coordinate system?
507
02-02-2021 05:37 AM
KathleenHoenke
When trying to mosaic two rasters, I noticed one had a projection but an unknown datum and therefore couldn't be mosaicked to the other. I attempted to define projection to what it should be and it definitely was not correct. Now, no matter what I do, I can't seem to define the correct projection and have it show up in the right place, and is now not even show ing up at all. Is there a way to fix this issue without having to recreate all of the rasters from scratch?
DanPatterson
MVP Esteemed Contributor
You have to define it back to what it was.
If the file was a *.tif, you could try deleting/renaming any file with the same name but different extension to (eg a *.tfw, *aux etc)
... sort of retired...
DanPatterson
