Rectangle for Clip_management tool in arcpy
6666
11
08-02-2010 08:57 AM
RichNauman
I have been struggling to get this part of a script to work. If I hard code the four coordinate pairs: like this:
rectangle = "-121.677618762735 42.7497214280392 -119.35205017646 45.3659860875993"
it works but we have to remember to change this every time we change study areas. When I run the script pasted below I get the following error:
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 325, in RunScript
    exec codeObject in __main__.__dict__
  File "C:\Documents and Settings\Administrator\Desktop\clip_test.py", line 13, in <module>
    arcpy.Clip_management (raster, rectangle, outraster)
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 7692, in Clip
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000840: The value is not a Envelope.
Failed to execute (Clip).
Here is my code:
import arcpy
arcpy.env.workspace = r"C:\Temp"
raster = "some_raster"
outraster = r"C:\output_raster"
extent = r"C:\GIS_Data\test_extent2.shp"
desc = arcpy.Describe(extent)
rectangle = desc.extent
print rectangle
# Clip_management (in_raster, rectangle, out_raster, {in_template_dataset}, {nodata_value}, {clipping_geometry})
print "Success!"
What am I missing?
Thanks!
RichNauman
Thanks for the help!!!
I'm not sure where I went off track but the following works:
import arcpy
raster = r"c:\GIS_Data\some_raster"
outraster = r"c:\GIS_Data\delete_me"
desc = arcpy.Describe(r"c:\GIS_Data\test_extent2.shp")
frame = str(desc.extent)
arcpy.Clip_management (raster, frame, outraster)
print "Done!"
JenniferCorcoran
Have you tried applying this code to several rasters from different resolution source imagery? Do you get the same extents in the long run?  I am having major trouble clipping my rasters to specific extents and having them come out the EXACT same. I keep getting some of them the same as I am trying to use and some with extra decimals (ex. Raster Extent Interested: 524002.75 5167611.25 542557.75 5188001.25; Raster Extent Result: 524002.74999979 5167611.25012111 542557.74999979 5188001.25012111).
Thoughts?
