Setting a default directory for an ArcToolbox file parameter
484
08-07-2021 05:28 PM
DavidTriggs
Hi Everyone,
I am trying to find out if it is possible to set a default directory location to use when using a File parameter in ArcToolbox.
The file data type allows for a default, but only a default file. When the user clicks on the folder icon to select a file the default location is the standard default location of the last file loaded into which ever program your using.
I have tried fiddling around in the validation settings, but can't find anyway of  doing this.
Has anyone been able to do this?
David
Tags (3)
ScottEllis123
I'd also like to see an answer to this 🙂
