Hi guys
Thanks for your response. I'm trying to access ADCIRC netcdf files via the
Thredds server at the OpenDap link here
http://opendap.renci.org:1935/thredds/catalog/tc/isaac/39/GM_LA_TX_v3_chk/blueridge.renci.org/hfip/nhcConsensus/catalog.html
I need to import an unstructured grid (fortran 14 file) into Arc to
visualize the water elevation from Hurricane Isaac along the coast, so I
need this dap2arc extension in order to create the dap2tin python tool that
will convert it to a tin in arc.
I downloaded and extracted the zipped folder, but when I try to pull it
into Arc like the guy in the video, the dap2tinapyt file shows a red "x";
Does this mean I need to first import the toolbox via python? I attached
the downloaded file for reference in case you need it.
Thanks!
