Zonal Statistics
249
02-18-2014 10:00 AM
by Anonymous User
Not applicable
Original User: kbancke
Good Afternoon.  I'm trying to calculate zonal statistics in a table using polygon areas over a raster.  The raster does not have an attribute table.  I've tried to use the Build Raster Attribute Table tool and get ERROR 000423 Only single band integer raster dataset is valid input.  I looked in the metedata and the data is single band. I have used the Times and Int tools to make all of the data integers to preserve the details I need.  I then ran the Build Raster Attribute Table again and it worked.  Then I tried to use the Zonal Statistics as Table again and received the 99999 error, which pretty much tells me nothing.  Does anyone have any ideas?  I really need to get this data and I've tried everything I can think of.  Thank you in advance!
