During ArcGIS 10.2 caching tiles I encountered with some errors but could not find any solution in web. What I found in web as solution was to make caching as foreground process (instead of background process) by clicking Geoprocessing > Geoprocessing Options on the Standard toolbar and uncheck background option. I did so, but errors continue flowing although caching process continues.
If I choose background cache process instead of foreground cache then cahcing halts.
What should I do?
I am getting following errors during cahcing (caching process continues):
Failed to cache extent: 2974329,588527 4931117,511619 3052577,218922 5009365,142013 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 2974329,588527 5009389,028585 3052577,218922 5087636,658980 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Output failure, error string = Unable to construct the map service instance.
Failed to cache extent: 2974329,588527 4618031,443754 3052577,218922 4696279,074149 at scale 9027.9774109999998 Xml Parsing failed.
Reason:XML document must have a top level element.
Linepos:0
Source:(null).
Failed to cache extent: 2974329,588527 4539759,926788 3052577,218922 4618007,557183 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 2974329,588527 4383216,892856 3052577,218922 4461464,523251 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 2974329,588527 4304945,375890 3052577,218922 4383193,006285 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 2974329,588527 4226673,858924 3052577,218922 4304921,489319 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 2974329,588527 4163969,476778 3052577,218922 4226649,972353 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3052601,105493 5165932,062517 3130848,735888 5176676,972045 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3052601,105493 5087660,545551 3130848,735888 5165908,175946 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3052601,105493 5009389,028585 3130848,735888 5087636,658980 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4931117,511619 3130848,735888 5009365,142013 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4852845,994653 3130848,735888 4931093,625047 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4774574,477687 3130848,735888 4852822,108081 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4696302,960721 3130848,735888 4774550,591115 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4618031,443754 3130848,735888 4696279,074149 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4539759,926788 3130848,735888 4618007,557183 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4461488,409822 3130848,735888 4539736,040217 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4383216,892856 3130848,735888 4461464,523251 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4304945,375890 3130848,735888 4383193,006285 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4226673,858924 3130848,735888 4304921,489319 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4163969,476778 3130848,735888 4226649,972353 at scale 9027.9774109999998
Failed to cache extent: 3130872,622459 5165932,062517 3209120,252854 5176676,972045 at scale 9027.9774109999998
Failed to cache extent: 3130872,622459 5087660,545551 3209120,252854 5165908,175946 at scale 9027.9774109999998
Failed to cache extent: 3130872,622459 5009389,028585 3209120,252854 5087636,658980 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 3130872,622459 4852845,994653 3209120,252854 4931093,625047 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3130872,622459 4774574,477687 3209120,252854 4852822,108081 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3130872,622459 4696302,960721 3209120,252854 4774550,591115 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 3130872,622459 4539759,926788 3209120,252854 4618007,557183 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3130872,622459 4383216,892856 3209120,252854 4461464,523251 at scale 9027.9774109999998 Xml Parsing failed.
Reason:Not enough storage is available to complete this operation.
Linepos:0
Source:(null).
Failed to cache extent: 3130872,622459 4304945,375890 3209120,252854 4383193,006285 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3130872,622459 4226673,858924 3209120,252854 4304921,489319 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:41
Source://///////////////////////////////////////.
Failed to cache extent: 3130872,622459 4163969,476778 3209120,252854 4226649,972353 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:7
Source:GRoaWVx.
Failed to cache extent: 3130872,622459 4461488,409822 3209120,252854 4539736,040217 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 3209144,139425 5165932,062517 3287391,769820 5176676,972045 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3209144,139425 5009389,028585 3287391,769820 5087636,658980 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3209144,139425 4931117,511619 3287391,769820 5009365,142013 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3209144,139425 5087660,545551 3287391,769820 5165908,175946 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 3209144,139425 4852845,994653 3287391,769820 4931093,625047 at scale 9027.9774109999998
Failed to cache extent: 3209144,139425 4696302,960721 3287391,769820 4774550,591115 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3209144,139425 4774574,477687 3287391,769820 4852822,108081 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 3209144,139425 4618031,443754 3287391,769820 4696279,074149 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3209144,139425 4461488,409822 3287391,769820 4539736,040217 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
