ArcGIS Javascript API change Home Button image
5387
05-20-2015 10:34 AM
JosephRogan
New Contributor III
How can I change the image/icon of the HomeButton (and other) widgets easily using the ArcGIS Javascript API?  Do I need to need to follow something like the "Create a Re-usable Widget" guide, or is there an nice easy way to just specify my own image url?
Thanks!
JosephRogan
New Contributor III
Thanks!
ChrisSergent
Regular Contributor III
If this worked for you I can mark Tim Witt's answer as correct. I don't know if you see that option since I created this group.
JosephRogan
New Contributor III
Yes, that helped.  In addition to the info in the links I also added some css, because by removing the span's text, there was essentially no element left to click on and trigger the action of the home button.  I had to make the span's text cover the entire button, not overflow, be transparent and not selectable. Actually there was a little more because I had to make the selectable text transparent as well since my work only uses ie9 and some of those items don't work.
.customButton span {
    color: rgba(0,0,0,0);
    line-height: 35px;
    display:block;
    overflow:hidden;
    -webkit-touch-callout: none;
    -webkit-user-select: none;
    -khtml-user-select: none;
    -moz-user-select: none;
    -ms-user-select: none;
    user-select: none;
