I would like to use the Apparent Reflectance Function with some Worldview-3 multiband imagery. However, the appropriate corrections do not populate from the metadata that is supplied by Digital Globe. I know there are a number of patches out there for desktop 10.3 with respect to the Worldview-3 imagery. Does anyone know if any of those patches resolve this issue, or if there are plans in place to make that function work with this imagery?
Here is the Worldview patch: Esri Support 10.3 (10.3.1)
You can also search for patches at a certain version of the software here: Esri Support Downloads
That is how I found the patch above. Hope this helps.
I have installed this patch, but it does not do anything to help populate the information needed to calculate apparent reflectance. I am not sure if this is a problem with the apparent reflectance function or the way the VW-3 data are interpreted but it still does not work.
