I'm trying to detect objects using deep learning; however, get the following error message: Error 160682: The maximum table size has been exceeded. Failed to execute (DetectObjectsUsingDeepLearning).
I've tried using both the GPU and CPU for processing without success. The training data was exported using PASCAL Visual Object Classes and the model trained using the RetinaNet-Object detection model type (resnet34 backbone model). Increasing the raster dataset maximum number of unique values to display a very large number also didn't help (Raster and Imagery raster dataset options). I'm using Pro 2.6.2.
Thanks.
Tony Viveiros
Hi Tony, I also encountered the same problem. Can you tell me how to fix it if you succeed to resolve it ?
