I often georeference floor plans of buildings. Since the floors are stacked, the coordinate transformations are the same from floor to floor. I will save the coordinate file from one georeferencing process and import the file for the other floors. This saves work and allows all the images to be stacked in the same place.
If I georeference in ArcMap the link file is a .txt with an associated .prj file. If I georeference in Pro I do not get a .prj file created. If I create an associated .prj file for the link file, I still cannot see the .txt file when I try to load the control point file in Pro.
Why can't I import control points into Pro georeferencing after exporting them from the same process?
