When I run a CLIP processing against a Infrared aerial I get a temporary output of an NDVI result. How do I get a scale of percentages of color as in a pie chart or a bar chart. Certain vegetation is represented by certain colors. How many pixels of each color in an area is what I am looking for.
Hi Kyle,
Take a look at the Zonal Statistics as Table tool. You can use the raster for the zone data, VALUE for zone field, and the same raster for value raster to retrieve all the statistics of each value.
Hi Kyle,
Jake,
I looked at the page briefly and it sounds like what I am looking for if I can get some tallies from the data for each “ZONE”.
Looks like I have a lot of reading to do.
Thank you for your quick reply..
Kyle
Flood Control District
