How do you add the Block Adjustment Window in ArcGIS Pro 2.3.2??
733
04-18-2019 05:11 AM
JurieTheron
Hi there.
Im new to the ortho mapping functionality of ArcGIS Pro, so I apologize for my ignorance.
I am trying to access the Block Adjustment Window as specified in this link here: http://desktop.arcgis.com/en/arcmap/10.3/manage-data/raster-and-images/block-adjustment-window.htm
But I am unable to find all these tabs and options.
I am trying to add ground control points to my Drone Imagery, but just using the normal Ortho mapping Wizard for generating ortho products, I get an error when recomputing Block Adjustments after Ground control points have been added. So I thought to not use the Wizard and follow this link to manually do all the steps needed for adjusting and refining drone imagery: http://desktop.arcgis.com/en/arcmap/latest/manage-data/raster-and-images/bundle-block-adjust-uas-or-...
But I cant find/open the Block Adjustment Window!
Any advice?
GuenterDoerffel
Follow the OrthMapping Workflow - creating a new OrthoMapping Workspace ... you need Pro Advanced for it ... and it will be exposed after initial steps are performed.
Guenter
Sent from mobile Phone
Am 18.04.2019 um 14:12 schrieb Jurie Theron <geonet@esri.com<mailto:geonet@esri.com>>:
GeoNet <https://community.esri.com/?et=watches.email.thread>
created by Jurie Theron<https://community.esri.com/people/jurietheron?et=watches.email.thread> in Imagery and Remote Sensing - View the full discussion<https://community.esri.com/message/846926-how-do-you-add-the-block-adjustment-window-in-arcgis-pro-232?et=watches.email.thread>
JurieTheron
Hi Guenter,
Thanks for your response. However, when I use the normal OrthoMapping Workflow, I get an error when trying to run the Adjustments again (after adding the GCP's). Thus trying to do it manually.
Has ArcGIS Pro removed the functionality of adding the Block Adjustment Window in the new patch?
GuenterDoerffel
I run 2.3.2 in en-us and have no issues at all with it:
Regards
Guenter
