The coordinate system for the "newmr" raster is incorrect.
Use Define Projection tool to define GCS_WGS_1984 as its coordinate system.
This would correct the problem, and the rasters would overlay on top of each other. If required, you can then use Project Raster to keep the coordinate systems same for both rasters.
Think Location
