Hi All,
ArcPro 2.4.1 on a 4 cores server, 12GB RAM (server). For some reason, the Adjustment process just used 2 parallel instances instead of 4.
I tried to reset the parallel processing factor to 100% by
import arcpy
arcpy.env.parallelProcessingFactor = "100%"
However, nothing changed. it took 50mins to finish the job
With the same project on my laptop, I got 4 parallel instances on 4 cores 8GB Ram laptop and took 33 mins to finish the job.
Do you have any idea how to force ArcPro to use more resource?
