I have downloaded ArcGis Runtime sdk, when I try to install it in eclipse, it won't show up. I don't know what i am doing wrong!!
Can you elaborate on "it won't show up"? Did you follow these instructions?
Hope this helps.
Thanks for replying! I am having trouble with this step
I am using Eclipse Juno? Is that ok?
If the contents of this folder do not look like the picture when browsing to it using windows explorer, then something went wrong with the installation. If they are there, the step states to only select the "folder", and not a file contained within. This will work with any eclipse version.
All that I can see is documentation and Support when I search? Should I just install ArcGis runtime sdk and install it again?
This folder should be located at "C:\Program Files (x86)\ArcGIS SDKs\java10.2.3\sdk\Eclipse Plugin". If not, I would re-install.
Thank you, I will try that now. Is there anything that affects the Eclipse Plugin from not downloading correctly?
Downloaded it again, but the files are still the same?
I'm a bit concern with your statement "anything that affects the Eclipse Plugin from not downloading correctly". The eclipse plugin of ArcGIS RT for Java is a component of ArcGIS RT for Java and NOT a separate component that can be downloaded and used without ArcGIS RT for Java being installed. Are we in the same page?
