I am developing an application with ArcGIS Runtime SDK for Java 10.2.3. This application creates a Map that includes a FeatureLayer created from the feature table (this table contains points) from a local geodatabase.The local geodatabase has been created by sharing a MXD document as runtime content. In that MXD document the labels are enabled.The feature layer shows points but not the labels.This is the source code:
GeodatabaseFeatureTable gdbFeatureTable = gdbPuntosEtiquetas.getGeodatabaseFeatureTableByLayerId(0);
capaEtiquetas = new FeatureLayer(gdbFeatureTable);
map.getLayers().add(capaEtiquetas);
I have tried to enable the labels with this code:
class EventosMapaListener implements MapEventListener
@Override
public void mapReady(MapEvent event)
// System.out.println("mapReady");
capaEtiquetas.setEnableLabels(true);
But the application fails y returns the following error:
Exception in thread "AWT-EventQueue-0" java.lang.UnsatisfiedLinkError: com.esri.map.FeatureLayer.nativeEnableLabels(JZ)V
at com.esri.map.FeatureLayer.nativeEnableLabels(Native Method)
at com.esri.map.FeatureLayer.setEnableLabels(Unknown Source)
at es.esri.emt.navegador.layers.EtiquetasLayers$EventosMapaListener.mapReady(EtiquetasLayers.java:196)
at com.esri.map.JMap.i(Unknown Source)
How can I show the feature layer labes?Regards.
