So I switched machines (a different Mac this one is a M1, with Java Azul JavaFX JDK 11) and I ran the following steps to just use a clone of an example
git clone https://github.com/Esri/arcgis-maps-sdk-java-samples.git
cd arcgis-maps-sdk-java-samples/map/display-map
gradle
gradle copyNatives
gradle run
And everything runs fine on that machine (window pops open and displays the map)
I switch back to the original Mac to go through the same steps and I get the following error
> Configure project :
Project : => no module-info.java found
> Task :run FAILED
2023-05-05 15:19:39.412 java[48567:646696] *** Assertion failure in -[_NSTrackingAreaAKViewHelper removeTrackingRect:], _NSTrackingAreaAKManager.m:1623
2023-05-05 15:19:39.474 java[48567:646696] *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: '0x0 is an invalid NSTrackingRectTag. Common possible reasons for this are: 1. already removed this trackingRectTag, 2. Truncated the NSTrackingRectTag to 32bit at some point.'
*** First throw call stack:
0 CoreFoundation 0x00007ff817d561ba __exceptionPreprocess + 242
1 libobjc.A.dylib 0x00007ff81787c42b objc_exception_throw + 48
2 Foundation 0x00007ff818c2beb8 -[NSCalendarDate initWithCoder:] + 0
3 AppKit 0x00007ff81b4213a5 -[_NSTrackingAreaAKViewHelper removeTrackingRect:] + 190
4 libglass.dylib 0x000000012b1f74e9 -[GlassViewDelegate setFrameSize:] + 361
5 libglass.dylib 0x000000012b1fcd68 -[GlassView3D setFrameSize:] + 88
6 AppKit 0x00007ff81adb05e1 -[NSView setFrame:] + 347
7 libglass.dylib 0x000000012b1fcdc5 -[GlassView3D setFrame:] + 69
8 AppKit 0x00007ff81adc13e4 -[NSView resizeWithOldSuperviewSize:] + 694
9 AppKit 0x00007ff81adc0d17 -[NSView resizeSubviewsWithOldSize:] + 499
10 AppKit 0x00007ff81ada0496 -[NSView setFrameSize:] + 1460
11 AppKit 0x00007ff81adb05e1 -[NSView setFrame:] + 347
12 AppKit 0x00007ff81adc13e4 -[NSView resizeWithOldSuperviewSize:] + 694
13 AppKit 0x00007ff81adc0d17 -[NSView resizeSubviewsWithOldSize:] + 499
14 AppKit 0x00007ff81ada0496 -[NSView setFrameSize:] + 1460
15 AppKit 0x00007ff81adbf120 -[NSThemeFrame setFrameSize:] + 464
16 AppKit 0x00007ff81adbe82b -[NSWindow _oldPlaceWindow:fromServer:] + 831
17 AppKit 0x00007ff81adbd2ca -[NSWindow _setFrameCommon:display:fromServer:] + 3045
18 libglass.dylib 0x000000012b1eeacf -[GlassWindow(Java) _setFlipFrame:display:animate:] + 239
19 libglass.dylib 0x000000012b1ee5cc -[GlassWindow(Java) _setWindowFrameWithRect:withDisplay:withAnimate:] + 268
20 libglass.dylib 0x000000012b1ee81b -[GlassWindow(Java) _setBounds:y:xSet:ySet:w:h:cw:ch:] + 571
21 libglass.dylib 0x000000012b2082fe Java_com_sun_glass_ui_mac_MacWindow__1setBounds2 + 446
22 ??? 0x0000000117914051 0x0 + 4690362449
23 ??? 0x000000011790fe9f 0x0 + 4690345631
24 ??? 0x000000011790fe9f 0x0 + 4690345631
25 ??? 0x000000011790fe9f 0x0 + 4690345631
26 ??? 0x00000001179102fb 0x0 + 4690346747
libc++abi: terminating due to uncaught exception of type NSException
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':run'.
> Process 'command '/usr/local/Cellar/openjdk/19.0.2/libexec/openjdk.jdk/Contents/Home/bin/java'' finished with non-zero exit value 134
I might try to use the same Azul JDK 11 version to see if the higher JDK is the problem...or just switch to Nasa Worldwind
