Solved! Go to Solution.
The service is not secured::
ArcGISTiledMapServiceLayer tiledLayer = new ArcGISTiledMapServiceLayer(
"http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
//LayerList layers = map.getLayers();
// layers.add(tiledLayer);
map.getLayers().add(tiledLayer);
even this is also not being displayed... i am getting same error.
Great! Thanks.
I just have one question. May be the proxy parameters are not correct. How can you catch this connection exception (org.apache.http.conn.HttpHostConnectException) since it's not thrown by JMap class itself. I need to catch this error and take suitable actions or an appropriate warning message about the proxy parameters correctness.
I tried:
MapOptions mapOptions = new MapOptions(MapType.STREETS, 24.43261, -102.92041, 4);
try{
JMap jMap = new JMap(mapOptions);
jMap.setWrapAroundEnabled(true);
catch(org.apache.http.conn.HttpHostConnectException){
// Handle error connection due to incorrect proxy parameters
But, of course, the compiler claims "Out of Reach try catch clause"
First of all, good "catch". by the way.
What happens when you try to catch a general Exception?
This is what works for me. Surround your layer definition code with a try/catch for Exception, instead of a specific one. I know it sounds improper, but this may get you farther along, hopefully?
