Will Java 1.6 work for ArcGIS Runtime for JAVA's Sample Code
2523
06-18-2015 11:59 AM
JamesFitzgerald
Occasional Contributor II
Help!
I am recently learning Eclipse and Java. I am also using the sample code provided by arcGIS Runtime for Java. I had several issues with the operators throwing errors. It stated the operators were not compatible with Java lower than 1.7. I am currently on 1.6. I will upgrade to see if it will correct the error. If anyone has experienced similar issues, please comment. THANKS! THANKS!
DanielleKnight
My experience is that using Java 1.6 will not work with the ArcGISRuntime for Java. Upgrading should fix the issue.
FreddieGibson
What version of the Java Runtime SDK are you using?  According to the documentation the current version of the SDK (10.2.4) no longer supports JDK 6.
