Thanks Jeff. Did you notice the problem prior to saving edits, or do you now have instances of control points stored in the database that have had the incorrect unit conversion already applied? If you (or anyone reading this) have a large number of instances of the wrong control points stored in the database as a result of this problem, there is a way that these can be repaired.
Since we know that the coordinates are getting a unit conversion applied, we can detect the control points that are well outside the proper extent, export them to a table (dropping some of the system fields), recalculate the X and Y fields by multiplying them by a scale factor, and then re-import them using the Control point Importer. Once it’s been determined that the process occurred correctly, then the control points that are in the wrong location can be deleted.
I’ve uploaded a toolbox to AGOL with a script for exporting the control.
Here are the steps to follow after downloading it:
- Drag the control fabric class that has the incorrect control points onto a new map.
- You should see two clusters of control points, one of the clusters being at the incorrect location
- Use the Zoom tool and zoom to the location of the incorrect control so that all are within the map extents
- In the toolbox double click the script called “Export Parcel Fabric Control To Table”
- Set the source table to be the Control layer
- For the Data Extent parameter, click the dropdown and pick “Same as Display”
- Choose the location for the exported table
- Click OK
- The table is added to the Table of Contents
- Open the Table
- Confirm that the X and Y values are well outside the correct range
- Right-click the X field column and click Field Calculator
If your original data is in US Feet then calculate as follows:
*0.3048006096012192
If your original data is in International Feet then calculate as follows:
*0.3048
- Do the same steps for the Y field column, and Calculate the
- Right-click the Fabric in the Catalog window, and click Import->Control Points
- Navigate to the table that you exported, and that you updated the coordinates on
- Accept the default values in the Control import wizard and then add the fabric to the map
- Confirm that the control points that had been changed are now back in the correct location
- If all’s OK, Start Editing, and go back to the incorrect control points, and delete them.
