Hello.
I have a complex model (with many tools/steps chained - named from "a" to "p") and I need iterate two input rasters (p1.img and p2.img), so that all the model outputs returned for the two input files. As there are many chained steps on the model, I applied the Parse Path output as a in-line variable substituition. My attempts and the problem were:
1) Multivalue iterator: return the outputs correctly but just in relation the file p1.img, doesn't run for the file p2.img. (image below)
2) Raster iterator: generate a kind of loop, running repeatedly and cumulatively outputs in relation of the file p1.img. (image below)
3) Turn the raster iterator and parse path tools as a submodel and add it into a main model that contain the steps: return the outputs correctly but just in relation the file p1.img, doesn't run for the file p2.img. (image below)
Questions:
- How run all the model steps for both input files p1 and p2?
Suspect:
- I suspect that the problem is the Parse Path tool, that in some way limit the model to run upon the first file (p1) only.
Can someone help me solve this?
Assuming both rasters are in one folder, I would think Iterate Rasters would be the way to go, and that using Name that is derived from the Iterate Rasters (as an inline-variable %Name%) would obviate the need for Parse Path.
So to start, I would troubleshoot why the Iterate Rasters is running as a loop.
Chris Donohue, GISP
Hi Chris.
BUG-000095577 RasterToPoint, RasterToPolygon and RasterToPolyline when run in Modelbuilder the second time appends .shp to the output featureclass name and fails to run.
is fixed in ArcGIS 10.5 and ArcGIS Pro 1.3+
-Steve
Hi Steve.
After your answer, I tested the model in ArcGIS 10.5 (trial version), and got the same problem ... In fact it seems to be a bug, because even in version 10.4.1 (before your answer), I built the model from begin again, adding the iterator, parse path, and the other tools, and the model worked perfectly (that is, running the steps for the two files p1 and p2) until a certain moment. After that, it started to run only for file p1, endless.
So, what to do if even on the ArcGIS 10.5 the problem does not disappear?
