Help with campus place locator room pop-ups
339
07-23-2018 09:12 AM
by Anonymous User
Not applicable
Hello,
I have got our campus place locator working fairly well however when you search a room name it doesn't select the room. The functionality works find for searching for an employee. does there need to be a related room table?
I also cannot click on a room to get a popup. Is there something I configured improperly?
Thank you
Luiz_AmadeuCoutinho
Occasional Contributor III
Did you find a solution? I got a similar problem here.
by Anonymous User
Not applicable
Yes actually I did. I found that I needed to make sure I specified a relate in pro before publishing to AGOL. Once I did that it worked for me.
